Re: Farmall M Replacement of Fan Belt
Posted by Andy Martin on November 20, 2002 at 07:04:35 from (12.74.160.183):
In Reply to: Farmall M Replacement of Fan Belt posted by Nick Williams on November 19, 2002 at 05:02:34:
Too much emphasis cannot be placed on letting the penetrant and tapping loosen the adjustable sheave. Use lots of patience and maybe let the penetrant sit a day or week.
When you have adjusted the belt, line up the set screw with one of the milled grooves in the threads. It avoids damaging the threads.
A little loose is much better than a little tight.
And don't forget to grease both grease zerks on the water pump, two shots each.
Post A Followup
: Re: Re: Farmall M Replacement of Fan Belt
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
