Farmall Tractors Discussion Board
Re: SA has slack in rear wheel
Posted by Curt Cooke on August 27, 1999 at 07:12:45 from (207.75.224.250):
In Reply to: SA has slack in rear wheel posted by Hugh on August 26, 1999 at 15:02:03:
Bearings are not adjustable. It is possible that the bolt that holds the whole assembly in is loose. This is a 5/8 fine thread cap screw on the inner side of the axle. It is more probable that the 4 bolts that hold the rim to the wheel are loose.
Post a Followup
: Re: Re: SA has slack in rear wheel
