Re: running liftall pump all the time?
Posted by Haas on November 20, 2002 at 13:22:21 from (166.72.245.171):
In Reply to: running liftall pump all the time? posted by jmyt_47 on November 20, 2002 at 11:34:03:
Ray is correct. The pump runs all the time that the clutch is engaged anyway. It circulates internally. When you pull the activating rod, it sends oil to the pressure ports and develops pressure if there is a cylinder there. If you have a two way valve with return to the fill port, it just cirulates back that way with no pressure until you activate the two way valve. Using the two way valve should make no difference on the life of the pump.
Post A Followup
: Re: Re: running liftall pump all the time?
