Re: Re: running liftall pump all the time?
Posted by jmyt_47 on November 20, 2002 at 21:18:28 from (128.101.254.58):
In Reply to: Re: running liftall pump all the time? posted by Steven@nd on November 20, 2002 at 15:40:40:
Thanks for the information on the GPM...wasn't thinking right when I said CFM..oops! Well that sounds like enough flow for a powersteering unit and the ability to run a 3 point easy...it may be a little low on the pressure. I think those charlynn units need 1200- 1500 psi max... Semi-live hydraulics is better than nothing. (This is for that other H I'm working on)
Post A Followup
: Re: Re: Re: running liftall pump all the time?
