Re: International 140 steering play
Posted by Hugh Mac Kay on November 22, 2002 at 02:59:39 from (216.208.58.138):
In Reply to: International 140 steering play posted by Merlin on November 21, 2002 at 07:25:14:
I have two of these tractors, and in one of them it was as shaggy describes. Half moon keys on the vertical shaft in steering box I my case the keyway was problem. I welded a key in shaft and ground it so cog had to be pressed on. The shaft was a throw away so what did I have to loose. That was 12 years ago, and steering is still tight.
My other tractor was tight on shafts, however someone with a good set of arms must have run tractor with no lubrication in steering box. Gear and worm teeth are worn. That one will not be a cheap fix.
Post A Followup
: Re: Re: International 140 steering play
