Re: Where can I get a sleeve puller?
Posted by Tony630 on November 22, 2002 at 17:29:09 from (64.24.84.156):
In Reply to: Where can I get a sleeve puller? posted by Doug Moser on November 22, 2002 at 16:07:20:
OTC - And it is NOT cheap! And they are not specific to IH. Truck diesel still use them today. If you've never used one before be very careful. You can crack your block if you have the wrong sleeve adapter on the end of the puller. Be VERY VERY VERY CAREFUL! You will get awful upset if you crack the block. DO NOT ALLOW THE SLEEVE ADAPTER TO BE BIGGER THAN THE SLEEVE.
Most of your Tractor dealers have a sleeve puller. Some will let you borrow it - some wil do it for a small nominal fee.
You can always take a wooden dowel and try to get them to move before borrowing or paying someone to do it for you.
Truthfully it is almost easier (if the block is out of the tractor) to take it to the local machine shop and let them put it in their press.
Tony630
Post A Followup
: Re: Re: Where can I get a sleeve puller?
