Re: Where can I get a sleeve puller?
Posted by aaron on November 23, 2002 at 16:07:33 from (172.190.92.65):
In Reply to: Where can I get a sleeve puller? posted by Doug Moser on November 22, 2002 at 16:07:20:
Maybe I am wrong, but if the cylinder is wet sleeved, as you mention it has rubber Orings, then you only need a hammer and a punch to remove them. Pullers are necessary for dry sleeves.
-aaron
Post A Followup
: Re: Re: Where can I get a sleeve puller?
