Re: Hydraulic Lift-all pump on M
Posted by Larry F on November 23, 2002 at 22:05:56 from (216.202.132.34):
In Reply to: Hydraulic Lift-all pump on M posted by Frank on November 23, 2002 at 20:46:50:
Frank - Sounds like you don't have the valve lever engaged. It is tricky to see as you attach the pump to the reservoir but it is a common and easy mistake to make. Take the reservoir off and realign it. Good luck.
Post A Followup
: Re: Re: Hydraulic Lift-all pump on M
