Re: 49 Cub Water in Steering Gear Box
Posted by George Willer on November 24, 2002 at 06:03:51 from (64.254.131.204):
In Reply to: 49 Cub Water in Steering Gear Box posted by Rick on November 24, 2002 at 04:04:46:
Rick,
You apparently have a good seal around the lower shaft, and a poor one on the steering shaft. Water can run down the steering shaft and get past a bad seal...and usually run out the bad seal on the bottom. :-(
The most damaging water will be below level of the drain plug, around the lower bushing and seal. You need a way to remove it...possibly by disolving it in alcohol (or turn the tractor upside down), before it ruins the shaft.
There is an additive for gear oil that will hold water in suspension so it can be removed. Maybe someone can direct you to it.
George Willer
Post A Followup
: Re: Re: 49 Cub Water in Steering Gear Box
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
