Re: Farmall H starting problems
Posted by Bob M on November 25, 2002 at 07:46:23 from (165.170.128.68):
In Reply to: Farmall H starting problems posted by bob on November 25, 2002 at 06:39:42:
Bob - There's several things you can do: 1 - If the battery cables are at all suspect, replace them with new. Use 1/0 cable and new, soldered-on (not crimped) terminals. 2 - While you are replacing the cables, recommend replacing starter switch too. They're cheap, and when worn can add resistance to the cranking circuit and make the engine crank slower. 3 - Remove the starter an check if the armature is stiff (you should be able to turn it easily with finger pressure on the bendix). If not oil the bushings at both ends. 4 - While you have the starter off, check the commutator/brushes. Clean and replace if required, and make sure none of the 4 brush holders are stuck. A couple other suggestions: Highly recommend you get the charging system fixed! Your method of operation (charging the battery when you need to run the tractor) works but will shorten the life of the battery, and it will cause the battery to have reduced cranking power. If you don't already, switch to a multi-weight oil (5W-30 or 10W-30) in winter weather. Lets the motor crank easier when it's cold. Good luck!!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
