1950 C Hydraulics and Compression
Posted by David Bean on November 25, 2002 at 08:33:58 from (128.110.9.125):
Hi all, Spent the weekend getting a 1950 C up and running again -- had to drill in some helicoils in the carburator body, make a new fuel line, and troubleshoot the 12-volt conversion. Couldn't have been a better way to spend a couple of days ;-). I've got two questions, though, that I'm hoping someone out there could help me with... First, I ran a compression test on the cyclinders and found pressures of 95, 95, 75, and 80. The 75 and 80 will come up to 90 or 95 if I put some oil in the cyclinders, so I think I've got those pegged as ring issues. I haven't got my tech manual yet, though, so I'm not sure if the 95 readings are satisfactory. Does anyone know what compression rate I should expect on the 113 engine? Second, I'm worried about the hydraulics. The levers themselves were really rusty...removed the linkages and I almost had to put a wrench on them to move them back and forth. Still, I got the levers loosed up, I greased the movement arms (not sure what to call those things), and I replaced the hydraulic fluid. When I engage the levers, I hear a nasty, high-pitched squeal...in either direction. It sounds like the system is laboring...the governor will jump up the idle when I'm doing this, so something is taxing the system. When I had the linkages off of the levers, I tried moving the rods they attached to (under the hydraulic reservoir), and they moved easily enough by hand. So I don't think they're frozen. My guess is that either the movement arms are tight, or the pump isn't operating efficiently. In any case, has anyone run into a similar situation before? If I were to start tearing down a part of the system, where do you think I should start? Many thanks, - David
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
