Re: why do diesel engines have,,,
Posted by Steven@nd on November 26, 2002 at 10:17:11 from (165.234.131.175):
In Reply to: why do diesel engines have,,, posted by Bryce Andreasen on November 26, 2002 at 08:10:25:
Bob M covered most of the points, but one major part of the start on gas diesels and the ones with glow plugs is the lower compression ratio.
Diesel engines use the heat of compression to lite the fuel/air mix. The older diesels didn't have high enough compression ratios to lite the mix at cranking speeds or cold temperatures.
Newer diesels have higher compression ratios and this contributes to the better cold starting.
Post A Followup
: Re: Re: why do diesel engines have,,,
