Re: Charging problem - odd ammeter reading (again)?
Posted by Bob M on November 26, 2002 at 17:15:09 from (24.169.120.229):
In Reply to: Charging problem - odd ammeter reading (again)? posted by SAm in NS on November 26, 2002 at 12:41:47:
Well SAm - That the ammeter pegs when you ground the generator says the generator is OK. That leaves either the regulator or it's grounding as the problem (I'm assuming the wiring is correct....)
Here's what I'd do: Take a short jumper wire and clamp one end firmly to the grounded battery cable terminal. (Vicegrips work great for this). Now with motor running at about 1/2 speed, touch and hold the other end of the jumper first to the regulator mounting base, then to the regulator relay frame base while observing the ammeter. Don't touch the relays themselves.
If the ammeter settles down and shows charge, you know you have a grounding problem at the regulator. If the problem persists you've got a defective (or possibly the wrong) regulator installed. Swap with a known good one if you can, or else head for the parts store.
Good luck!!
PS - The "flapper bit" on the top of the relay you refer to is properly called the relay armature. Always helps to know the lingo!!
Post A Followup
: Re: Re: Charging problem - odd ammeter reading (again)?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
