Re: Super A radiator
Posted by Red Dave on November 27, 2002 at 06:50:39 from (24.104.94.34):
In Reply to: Super A radiator posted by Ricky on November 27, 2002 at 06:32:27:
I think the radiator drain for a Super A is the same as an A.
Look on the left side of the tractor, in front of the engine, beneath the steering bolster for a small pipe with a plug or cap on it. It comes out of the lower water inlet to the engine, not the radiator itself. This is the cooling system drain.
If it is not there, someone may have broken it off, in that case, look for a plug in the bottom of that lower water inlet, or you may have to loosen the lower hose and slide it toward the engine to drain it.
Post A Followup
: Re: Re: Super A radiator
