Re: long winded plow problem for an A
Posted by Dave, Sherburne, NY on November 27, 2002 at 18:13:43 from (216.238.58.227):
In Reply to: long winded plow problem for an A posted by Kurow on November 27, 2002 at 00:23:23:
I have what I believe is an A192 and it does
mount by hitching to the front of the tractor
where that square hole goes through the casting
though I just got it a month ago, and havn't
mounted it on the tractor. the book also indicates that it attaches to the lift arms on
the back to raise it. THAT SAID, I have seen
a plow mounted on a Super A by reversing the
drawbar, and attaching it to the lift arms
to raise it. It fastens to the drawbar with
a floppy steelthing with 2 bolts I believe.
My A192 has just a hole thru the front of the
beam . Hope this helps.
Post A Followup
: Re: Re: long winded plow problem for an A
