Re: Re: Re: Broken cylinder head stud
Posted by frankie on November 28, 2002 at 17:16:40 from (206.26.221.92):
In Reply to: Re: Re: Broken cylinder head stud posted by redhead on November 27, 2002 at 18:23:40:
id agree with andy that stud should never break if you are using a torque wrench. Do you have the right foot lbs set on your wrench? Also are all the studs cylinder head grade studs? They are probably at least a grade 5. Also is this a bolt or stud? also clean holes ouy make sure you are not bottoming out which still wouldnt cause breakage-oil-too
Post A Followup
: Re: Re: Re: Re: Broken cylinder head stud
