Setting of H timing gears
Posted by Randy on November 29, 2002 at 09:58:14 from (64.12.97.13):
Hello all,
I need you help again with my '43H. I am not seeing on my crank and camshift gears what the IT service manual says I should see.
I have only a single marked tooth on the crankshaft gear. I have a single marked tooth and a double marked tooth on the camshaft. The magneto gear has only a double marked tooth.
Is my timing setting to line the single marks on crankshaft and camshaft, and line the double marks on the camshaft and magneto?
Randy
Post A Followup
: Re: Setting of H timing gears
