Re: Oil Pressure Problem
Posted by Will@ont.ca on November 29, 2002 at 10:00:55 from (209.226.251.165):
In Reply to: Oil Pressure Problem posted by Todd Davis on November 28, 2002 at 16:47:45:
Todd,three year's ago I and my bro/in law,"who is a tractor machanic" rebiult my Super"A" with everything,anything that could be replaced was replaced.On start up the oil pressure reads 40lbs after warmed up on an idle it reads 10-15 max.I was a little worried at first but as time went on everything seemed to work OK.I work it about 200hrs a year and if you change the oil in the spring it might use a 1/2 a quart of oil all year.So if your engine sounds alright for work/parts you put into it I wouldn't give it another though. GOOD LUCK!!! Will
Post A Followup
: Re: Re: Oil Pressure Problem
