Re: Hydraulic oil in base of engine
Posted by Dave_Id on November 29, 2002 at 17:14:15 from (67.250.134.120):
In Reply to: Hydraulic oil in base of engine posted by Murray on November 29, 2002 at 17:10:02:
What do you mean by base of engine? The crankcase? If the oil went into the crankcase, it's an indication you have some bad orings on your hydraulic pump... easy to replace. If you mean the oil drained into the casting below the touch control tank, then you need to replace the gasket on the bottom of the tank
Post A Followup
: Re: Re: Hydraulic oil in base of engine
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
