Re: Re: Hydraulic Touch Control Breather
Posted by Al on November 29, 2002 at 19:09:38 from (63.175.62.135):
In Reply to: Re: Hydraulic Touch Control Breather posted by Peabody on November 29, 2002 at 18:06:11:
If everything is in good working order, it will not build up excessive heat, unless you allow a mounted implement to strike the bottom of the tractor such that the lift arms can't complete their cycle.
Did you fill the system with the lift arms in the retracted (rearward) position? I think that would prevent a pressure buildup during use.
Al
Post A Followup
: Re: Re: Re: Hydraulic Touch Control Breather
