Re: H hydraulics
Posted by The Undertaker on December 02, 2002 at 08:32:39 from (64.40.66.163):
In Reply to: H hydraulics posted by SteveW/swMI on December 01, 2002 at 06:31:51:
Steve!
I've a 40 H with Work Saver 3pt hitch. I mounted two Lion 2500 3" X 8" Cylinders to it. Run hose from right side Lift-All to bottom (Cyldr end) on right side of hitch, and from front outlet of Lift-All to bottom (Cyldr end) on left side of hitch. However, because of using double action cylinders I had to install vent plugs to each cylinder at their piston end for what would otherwise would been recirculating hose connections. As "Red asked", it may well depend on what you want to use it for, but I've used the above set up with a 570 lb BEFCO 6ft grooming mower and has worked just great.
"TU"
Post A Followup
: Re: Re: H hydraulics
