Re: F-20 brakes
Posted by Al P. on December 02, 2002 at 16:19:10 from (208.253.189.149):
In Reply to: F-20 brakes posted by Jeff on November 30, 2002 at 12:07:47:
I had a simular problem with my F-20. after washing i backed it into the garage and stoped with the brakes. the next time i wenty to move it the brakes were locked up tight on one side. upon teardown i determined the surface of the shoes contained enough cast iron from the drum that the mosture that got in there from washing bonded the shoe to the drum. the only solution after relining was to keep the brake system a little loose.
AL P.
Post A Followup
: Re: Re: F-20 brakes
