Re: f-30 stuck
Posted by aaron on December 02, 2002 at 17:35:55 from (198.81.27.16):
In Reply to: f-30 stuck posted by howster on December 02, 2002 at 07:55:02:
I had a stuck M the same way. Water standing in the cylinders. sponge out all the water and then put liquid wrench on top of the pistons. After the rods are unbolted from the main, use a dead blow hammer, not a sledge, and a 1" diameter wooden dowel. Place the head of the dowel on the piston wrist pin and not the underside of the flat top piston. Then bang away up and out the top. This worked for me, I did not break a thing and the tractor had been sitting for 20 years!
-aaron
Post A Followup
: Re: Re: f-30 stuck
