Re: What is an A worth?
Posted by Farmer Bob on December 02, 2002 at 20:26:41 from (66.152.73.210):
In Reply to: What is an A worth? posted by Kyle on December 02, 2002 at 19:33:12:
If it has sat that long it could be stuck, tires will be rotted out, seals will leak, clutch disc stuck to pressure plate, etc, etc. Unless it runs and you can drive it around to check the gears, brakes, etc., $150-$200 would be my offer. Also a lot depends on what you want to do with it if you get it. A's don't have hydraulics other than the pneumatic lift which does work if maintained properly if this one is so equipped. Suit yourself, I'd look around for one that's running. There are a lot of A's out there.//FB
Post A Followup
: Re: Re: What is an A worth?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
