Re: Int 10' Grain Drill
Posted by JD on December 03, 2002 at 14:42:30 from (209.240.198.63):
In Reply to: Int 10' Grain Drill posted by Avery on December 03, 2002 at 06:34:05:
Does that grain drill have power lift? Or are you talking about hand lift.
IH made the model M. If it's a real old M it could have hand lift.
You could also get a Hydraulic lift attachment for the moael M. I had a 8ft and now i have a 10ft model M. My 8ft and 10ft have 2 levers. A clutch on each side.
If you drill has clutch type power lift with 2 levers, i think i have the levers from my old 8ft. They say you cant get parts for the M from CaseIH
Post A Followup
: Re: Re: Int 10' Grain Drill
