Farmall Tractors Discussion Board
Re: Use of unleaded Gas
Posted by PETE-TEX on August 28, 1999 at 10:23:53 from (152.163.207.67):
In Reply to: Use of unleaded Gas posted by paul on August 27, 1999 at 10:13:03:
USE MY "M" FOR WORKING A 20 ACRE FIELD, FOUND IT
RUNS COOLER UNDER HEAVY LOADS WITH LEAD ADDITIVE.
USED TO HAVE TO COOL DOWN AFTER A COUPLE OF
ROUNDS, NOW I ONLY HAVE TO COOL DOWN MYSELF. I
THINK IT MUST BE GETING A HIGHER OCTANE WITH IT. I
USE INSTEAD-O-LEAD, AND A LITTLE MARVLES IN THE
TANK FOR PIECE OF MIND. PULL A HOEME CHISEL,
TANDEM DISC (BOTH REDUCED TO 10 FT), OR CHISEL +
GRAIN DRILL COMBO..
Post a Followup
: Re: Re: Use of unleaded Gas
