Re: just making sure i undrestand,
Posted by jim on December 03, 2002 at 19:42:24 from (216.248.126.55):
In Reply to: just making sure i undrestand, posted by Bryce Andreasen on December 03, 2002 at 19:27:06:
You can put a 12 volt Delco "one wire" alternator on any older tractor and it will work great, but you do need to watch the pulley size on the alternator. If it is very big you won't get much of a charge at idle speed. The 6 volt starter will work ok as long as you don't crank too long on it at any one time (which you shouldn't have to after the conversion). The magnetos don't make any difference because they don't use the battery for ignition. The make their own spark. You will need to change any light bulbs to 12 volt or they will burn out very quickly. If you have a coil ignition just change over to a 12 volt coil with a built in resistor so it won't burn up the points.
Post A Followup
: Re: Re: just making sure i undrestand,
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
