Re: just making sure i undrestand,
Posted by CNKS on December 03, 2002 at 19:52:18 from (207.178.96.214):
In Reply to: just making sure i undrestand, posted by Bryce Andreasen on December 03, 2002 at 19:27:06:
I prefer to leave it 6 volt. However, I can answer a couple of your questions. 6 volt starter is fine. I had my H out of time a couple of years ago and cranked and cranked over a period of about a week before I found the problem, starter is still good, don't be concerned about it. Mag is completely separate from either 6 or 12 volt, you don't need to do anything. -- You have a mag on a 400? Distributer was standard, I guess mag was still optional. If you don't want to use an alternator, the generator can be changed to 12 volt, but it's more than just the regulator, someone else will have to tell you how to do it.
Post A Followup
: Re: Re: just making sure i undrestand,
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
