Re: SEiZE SUPER C
Posted by gene b on December 04, 2002 at 04:26:50 from (63.15.134.107):
In Reply to: SEiZE SUPER C posted by BEn Wolfgang on December 03, 2002 at 15:47:26:
You are going to need the head of anyway cause if the engine is stuck the valves are in bad shape also. After the head is off you can see how bad the walls are. Then you can go from there. The rings are probably stuck on one or more pistons also so you need the head off anyway. I have never seen an engine that things were good inside if it is stuck as sooner or later you are going to pull the head and do valve work. So pull the head and do it rite.
Post A Followup
: Re: Re: SEiZE SUPER C
