Re: Smokey Farmall Super H
Posted by CD on December 04, 2002 at 07:45:49 from (209.245.226.136):
In Reply to: Smokey Farmall Super H posted by Matt on December 04, 2002 at 06:58:14:
Same thing with my SH. If its only got blue smoke for a short time after starting it up thats normal. Oil likes to leak past the valves. If it does it constantly like mine did then you need to give it the wet/dry compression test. Do a compression test on each cylinder and record the results. Then go back and squirt oil ontop of the pistons and record each cylinder. If the compression goes up on the wet test the its the rings. If not, its the valve seals.
Post A Followup
: Re: Re: Smokey Farmall Super H
