Re: Smokey Farmall Super H
Posted by SAm in NS on December 04, 2002 at 09:37:32 from (24.138.71.44):
In Reply to: Smokey Farmall Super H posted by Matt on December 04, 2002 at 06:58:14:
I don't know what you've done to it so far but if you haven't you should change the oil in the air filter and engine (you should probably do the others as well but won't affect your smoke problem). If there is too much oil in either the engine or the air filter, or if it is too light a weight or diluted with gas (can happen if you don't shut off the gas under the tank) it could be sucking oil in from either. My Super A smoked when I bought it and this fixed my problem. Hope this helps. SAm in NS
Post A Followup
: Re: Re: Smokey Farmall Super H
