Re: Front crank seal on B
Posted by Gordon {Tx} on December 04, 2002 at 09:46:20 from (65.197.75.28):
In Reply to: Front crank seal on B posted by Rodger Wells on December 04, 2002 at 05:58:15:
Rodger I'm gonna try to help ya here. I totally disassenbled mine during rebuild, so some of what I tell you to take off you might not have to, but you should be able to tell what needs to come off as you go along. First Grille & radiator. Disconect steering & jack tractor up & block it under clutch housing just enough to clear the ground. Remove the four bolts that hold the front bolster on & roll it out of the way. That part is heavy, but not so heavy you can't handle it. This may or may not be a necessary step, but will make easier access to the front cover of the engine.
Remove the fan. Your gonna have to remaove the governor & then the crank pulley, be careful becasue it will break if you pry on it. Use a bearing puller to do this. once ya get all that off remove the front cover bolts & the cover will come off. The seal goes in from the back side. I hope I have helped & not confused you too much. It sounds like a lot, but it's really not that bad. And if I have told you wrong I'm sure someone will correct me. Let me know if I can help ya anytime.....Gordon. P.S. and scotch those rear wheels so she don't roll on ya. Above all be safe.
Post A Followup
: Re: Re: Front crank seal on B
