Re: 826 hydro
Posted by Robbie on December 04, 2002 at 11:53:52 from (208.54.197.78):
In Reply to: 826 hydro posted by Jeff on December 03, 2002 at 19:21:36:
It will pull a two row chopper but your not getting much speed, them 826s are rated about 90hp to pull a two row comfortably you need around 120hp, if you had a one row chopper behind it you could do just fine, you can pull a two row but believe you me you will know its back there, try putting a turbo on it and crank out about 120 or 130hp you can go then, Ive seen them 358c.i. motors with turbos on them cranking 150hp.
Post A Followup
: Re: Re: 826 hydro
