Re: Found a Farmall Super C
Posted by Peabody on December 04, 2002 at 16:53:28 from (205.188.209.78):
In Reply to: Found a Farmall Super C posted by Richard C on December 04, 2002 at 14:07:20:
Go for that C! My dad's had been sitting up for almost 25 years in the open with NO cover over the exhaust and was stuck. After soaking the cylinders for a couple of weeks to unsuccessfully free it, I pulled the head. The #4 piston was obviously rusted tight. I took a block of wood and tapped the top of the piston and had it free within 10 minutes. I had the head reworked, and the thing runs like a sewing machine. If yours has been under cover all this time, and nothing else is wrong, you should have no trouble getting it to turn over.
Post A Followup
: Re: Re: Found a Farmall Super C
