Re: f-20 gear swap
Posted by Chuck on December 04, 2002 at 20:10:59 from (24.149.29.149):
In Reply to: f-20 gear swap posted by Dave Houghton on December 03, 2002 at 14:34:59:
You must remove the rear wheels and differential. Been there done that. It sounds like you are going to do some pulling. F30 rocker arms will work if you use a super C rocker arm stand. The 30 rocker arms will give more lift but you may have to machine the top of the valve guide.
Post A Followup
: Re: Re: f-20 gear swap
