Re: f-20 gear swap
Posted by Ed-Ga. on December 05, 2002 at 06:35:10 from (216.78.54.174):
In Reply to: f-20 gear swap posted by Dave Houghton on December 03, 2002 at 14:34:59:
The pinion and transmission shaft come out the front and gears out top. Not difficult. With a parts book and the IH "Serviceman's Guide Shop Service Manual" (which covers F and W series tractors) you will see more clearly the procedure.
Post A Followup
: Re: Re: f-20 gear swap
