Re: FARMALL 130 CRANKSHAFT PULLEY
Posted by Duane on December 05, 2002 at 09:48:52 from (216.138.160.185):
In Reply to: FARMALL 130 CRANKSHAFT PULLEY posted by JARROD on December 05, 2002 at 09:19:24:
I just put the pulley back on my A this past weekend. I heated it in the oven to 450F for about an hour. It just slid right on the crank shaft. I had a bucket of water and wet rags ready. As soon as the pulley was on I put a wet rag on it by the seal and cooled it off. I have not started running the tractor yet to see if I damaged the new seal but from what I understand the seal will take the heat okay for a short time. Make sure the pulley is good and clean otherwise you will smell up the house when you heat it in the oven.
Post A Followup
: Re: Re: FARMALL 130 CRANKSHAFT PULLEY
