Re: FArmall A starter
Posted by Larry (again) on December 05, 2002 at 16:47:54 from (216.212.40.170):
In Reply to: FArmall A starter posted by Tom on December 04, 2002 at 18:12:26:
Just re-read your post. sounds like the starter is running...I'd say the first thing to do it crank it by hand and see how hard it turns over. If it cranks normally (by hand) then you've got an electrical problem--starter, bad cable(s), bad ground, etc. It should start without the starter, just cranking by hand, if every thing else is right. Do you happen to know any other tractor guys around you? Maybe you could get one of them to help you. Good Luck.
Post A Followup
: Re: Re: FArmall A starter
