Re: Re: Re: Oil Weight Makes A Difference!!!
Posted by SteveW/swMI on December 06, 2002 at 09:30:43 from (216.163.52.107):
In Reply to: Re: Re: Oil Weight Makes A Difference!!! posted by AL on December 03, 2002 at 17:24:44:
I plan to use 15w40 in all tractors starting in spring (use in our JD diesel which moves lots of snow) Believe info that says this oil will work fine in older (JD "B" and IH "H" & JD "M") rigs. A "must" is the 5w30 for the newer trucks (98 & 99 fords). Tight clearances require the quick flow of lubrication I'm told.
Post A Followup
: Re: Re: Re: Re: Oil Weight Makes A Difference!!!
