Re: Stuck brake on my H?
Posted by Michael Soldan on December 09, 2002 at 05:46:34 from (216.46.130.21):
In Reply to: Stuck brake on my H? posted by Sean Brinston on December 08, 2002 at 16:11:44:
Sean both brake peddals should be released back to the deck of the H . If one is 4 inches ahead of the other it could be stuck on. Steven is correct about the possibility of water frozen in the rear. You may have to pull the brake pan off. Remove the clevis for the brake you suspect is stuck and remove the studs that hold the brake pan on(cover). Everything should come off together but my experience is that you may need to heat, hammer and pry to get a stuck brake off the tractor. Give me a shout if you need some brake advice.MIKE in Exeter Ontario
Post A Followup
: Re: Re: Stuck brake on my H?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
