Re: hp of a early H and later C
Posted by Farmall Daddy on December 09, 2002 at 09:05:52 from (165.139.17.193):
In Reply to: hp of a early H and later C posted by Steve II NE. on December 09, 2002 at 06:34:42:
The H was built between the years of 1938-1953. The H original was 22-25 maximum belt horsepower. The C was 18 horsepower on the belt. If you bore an H out, you are able to get at least 38-45 maximum on the belt.
Post A Followup
: Re: Re: hp of a early H and later C
