Re: carb on H
Posted by Levi Gray on December 10, 2002 at 13:32:37 from (216.240.72.14):
In Reply to: carb on H posted by chuck on December 10, 2002 at 12:50:58:
Chuck most likely the problem is not your carb. It is probably your ignition system. There is a simple test to see if you have any fire reaching the spark plug: 1. Find a piece of wire about 6 inches long 2. Put one end of the wire in the end of the plug wire and hold the other close to the engine block or spark plug 3. Hit the starter button WITHOUT the kill switch on 4. Repeat #'s 1 and 2 with all four cylinders If there is a small blue spark on all four cylinders it is not your ignition system and then it may be your spark plugs have gone bad or it could even be your carb (not likely from what you have said it is doing) If there is no spark check all your ignition components like the rotor, point gap, points and condensor, see if the shaft is turning (if shaft is not turning call a professional and have him look at it) If all of this is working correctly it is your carb or it could even be that your valve tappet clearence is incorrect or your distrubuter is a little bit out of time (CALL A PROFESSIONAL TO COMPLETE ALL OF THIS WORK FOR YOU) I don't meen to try and empty your pocket book but I am a semi experienced tractor restorer and do reccomend that you do call a PROFESSIONAL for work that you don't know how to do. Levi's Tractor Repair Golconda, IL
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
