Re: Hydraulics on a '53 Super H
Posted by Don LC on December 11, 2002 at 10:01:45 from (24.166.248.35):
In Reply to: Hydraulics on a '53 Super H posted by MattM on December 11, 2002 at 06:22:32:
You may not be giving it time to work.....the cylinder connected to the left rear port is on the delay port......how it works....if you were plowing corn and you came to the end of the rows, with the tractor still moving pull the lift rod....the front cultivators will raise, as the tractor moves on the rears will raise at the same spot the fronts did.......make your turn and drop the cultivator at the begining of the row.....as the tractor moves on the back will drop at the same spot......thus this is called the delayed port..........
Post A Followup
: Re: Re: Hydraulics on a '53 Super H
