Re: C head studs
Posted by 306m-puller on December 11, 2002 at 17:39:56 from (64.12.97.13):
In Reply to: C head studs posted by CNKS on December 11, 2002 at 11:48:59:
like joe said, use some good penetrating and they should break loose. when i took the studs out of my M i soaked them for a good 2 days and most of them came right out. two of them twisted off. all we did was drill a hole all the way through the broken stud and then make two cuts down the stud using a good 00 tip on the torch and then you can take a punch and knock the two halves out. then run a tap through it to clean up the threads. just my experience
Post A Followup
: Re: Re: C head studs
