Re: C head studs
Posted by redhead on December 11, 2002 at 18:35:52 from (65.234.210.65):
In Reply to: C head studs posted by CNKS on December 11, 2002 at 11:48:59:
Learned this lesson the hard way! Studs were not corroded, but the threads had been torqued too many times! Thought I'd cut a corner and add an extra washer or two. Blew the head gasket first thing. Got all the studs out but one, twisted it off (most turned right out, some had to be heated and tapped with a hammer, one was a #$%^&**). Luckily it broke down in the block about 3/16 so the center was easy to find with a drill bit that would just clear the threads. Used a magnetic base (Ironworker's drill) set up on the deck. Drilled it out and chased the old threads with a tap. Studs aren't cheap, but the alternative is by far more costly. Good Luck.
Post A Followup
: Re: Re: C head studs
