Re: Rear wheel bolts
Posted by Haas on December 12, 2002 at 05:55:07 from (166.72.245.223):
In Reply to: Rear wheel bolts posted by Pete on December 11, 2002 at 16:18:52:
The correct bolts to attach the rim to the hub are square head bolts. You can get them at an IH dealer, but they will be expensive, probably $8 each or so. If you get them elsewhere, be sure they are at least grade 5 bolts. Lots of the aftermarket cheaper square head bolts I have seen advertised turn out to be grade 2 bolts. Grade 2 is not sufficient for this application.
Post A Followup
: Re: Re: Rear wheel bolts
