Re: What can an M do?
Posted by joe on December 13, 2002 at 06:28:58 from (66.43.207.226):
In Reply to: What can an M do? posted by David on December 12, 2002 at 18:22:01:
It will handle it with finess. I use our 300U on a 7 footer. Our 400 (comperable to your M) can do ANYTHING with that seven footer, and your ground speed is not limited by how much grass you have, but by how much bouncing you can take. I think that a 400/M could pretty easily handle a 14 footer or so, though I've never tried it. I use JD pull-behinds, which are kind of hard on drawbars because of their weight, so I haven't tried the 14 footer on it yet.
Post A Followup
: Re: Re: What can an M do?
