Re: What can an M do?
Posted by Scott(TN) on December 13, 2002 at 06:52:09 from (138.164.194.139):
In Reply to: What can an M do? posted by David on December 12, 2002 at 18:22:01:
I pulled a 7ft with a 400 (similar to the M) and the tractor needs work. 3pt cutter with fasthitch adapter. Cleared an overgrown rolling pasture, saplings-tall grass, and did not feel the cutter was back there.
Post A Followup
: Re: Re: What can an M do?
