Re: IHC 656 Gas
Posted by Yellott Canby on December 13, 2002 at 18:02:19 from (216.158.80.44):
In Reply to: IHC 656 Gas posted by John Pawlicki on December 13, 2002 at 17:46:19:
Hello,
I own a 656 gas 1966 model. It is a narrow front end 3 point hitch. I use it for the majority of my work from grinding feed to planting to mowing with a 15 ft batwing.
Two years ago I did a major out of frame rebuild on it. It had last had bearings put in 1972 according to the date on the bearings. I changed the sleeves and everything else.
The tractor has around 5000 hres on it.
Six thousand seems a bit high to me but the loader is worth a fair amount. I would like to have a loader for my 1466.
You may want to take an oil pressure gauge and screw it in to one of the plugs along the oil passage to check the pressure, as the tractor is only equiped with a light and may not be right anyway. Good luck. They are good tractors, the gas ones will start in the bitterest weather. May need that directly. YC
Post A Followup
: Re: Re: IHC 656 Gas
