Re: Farmall 300 - TA adjustment
Posted by Jon on December 13, 2002 at 18:36:32 from (66.141.235.244):
In Reply to: Farmall 300 - TA adjustment posted by James on December 13, 2002 at 16:16:55:
Your TA clutch is not releasing when you are pressing in the engine clutch. There is a short linkage between the TA clutch release shaft and the engine clutch release shaft. Take the pin out at the TA end and turn the turnbuckle in 1-2 turns to begin with (ie shortening the linkage). See if that works. If not turn it 1-2 more turns, that should be more than enough to do the trick.
Post A Followup
: Re: Re: Farmall 300 - TA adjustment
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
